KS 2.046 Crash with Win x 64Bit
Started by elzaan1, July 26, 2010, 07:18:12 AM
elzaan1
Hi - The trial keep crashing with Win 7 x 64 Bit and the textures eg. the wood texture do not orientate correct.
In crashing;
1. While working and adjusting the texture (any one )
2. In rendering it keep crashing, making it impossible to render.
Is this an isolated problem ?
KS 1.9 did not do this and is this an isolated issue ?
We are running the same setup here and can't reproduce the crashes. Also make sure that you are running the latest.
As far as the texture goes, you may want to change the mapping type to "box".
elzaan1
Well I downloaded Bunkspeed - no problems. I updated codecs for what it maybe helping, not working, I have setted the render adjustmenst to the lowest, nothing helps, I have it on 800 x 600 which is ridiculious and it Keyshot stil blanks out! I see on the Alibre Forum there is guy with similar "hanging" problems in KS but his PC does not blank out, only hanging. Great idea for rendering but not working - hate to see what it will do with a 544MB file to be done which VectorWorks can handle ?
I think the best option currently is to keep TurboCad and import your models in there and have better results with the option of cad related tweaks it allows and just as fast.!!!
What version of KeyShot are you using, and where did you download it?
