Author Topic: How to fake water animation  (Read 5871 times)
Offline abedsabeh
« on: August 27, 2013, 10:26:52 am »
This is a tip on how I made the water animation in Newton's Cradle. I hope it will be useful for you.
1- Create a plane with a geometry surface of the water as you see it in the animation (a real water surface).
2- Make the surface big enough so you can animate its position in the Y and Z axis with a little bit of Y rotation.
3- let the surface fit the area where you want the water to be seen.
4- Use a proper nice environment (reflection helps a lot for a realistic look)
Enjoy!
Abed
http://imageshack.us/photo/my-images/211/5ejllkehtpaeegmspobluw.mp4/
Offline richardfunnell
Re: How to fake water animation
« Reply #1 on: August 27, 2013, 03:34:17 pm »
Very nice! That's a great effect, I was wondering how it was done :)
Now it makes sense that you created the water geometry (instead of using the procedural bump), because I can see the waves having an effect on the edge of the pool instead of being flat. Thank you for sharing!!!
Offline Josh3D
« Reply #2 on: August 28, 2013, 06:38:11 am »
yes, thanks for sharing Abed, this is indeed a very nice effect.
