problem bumpmap glass material
Started by blender974, September 18, 2013, 05:46:50 AM
blender974
I added a bump map has KeyShot to fit holes in a water bottle.
rendering problem when I zoom the picture there is the small waves (see picture)
What do you think? how to eliminate it?
thank you :)
http://img199.imageshack.us/img199/3550/l0n8.jpg
sorry for my english, i am french  ::)
It's hard to say. Would you be able to send us the BIP and the bump map as well? If so, please use https://keyshot.wetransfer.com/ and send to chad@luxion.com or support@luxion.com.
Thanks,
Chad
blender974
thank you for your answer
Unfortunately this is a project agency, I can not transfer files.
I just saw that the problem comes from the displacemap. not everything is great, there is a problem, maybe the problem comes from the generation of displace?
Okay - well, you may need to bump up the quality of the displacement map or subdivide a couple more times before exporting. Depending on how close of a shot it is, you may get by using a bump map here.
blender974
effectively
UV remapping, export of diplacement 32-bit (instead of 8) and OpenEXR rendering is top!
;)  thank you
