Creatures in the night
Started by Ovidiu Enache, November 02, 2013, 03:15:29 AM
Ovidiu Enache
Hello! This is my first entry. Thanks for watching
Ovidiu Enache
The first image is after the comp the second one is what came out from keyshot.
Threiz
Well done ! i really like the post prod you did :)
Ovidiu Enache
Ovidiu Enache
#4
Hello again ! Here is a new creature that I'm posting. It's amazing how many polygons keyshot can handle, actually I didn't use deciamation master, its all highpoly from zbrush  ;)
Ovidiu Enache
And here is the actual render that came out from keyshot.  Thanks !
TpwUK
Impressive work again ... What was the final poly count ? I have had KS handle a 52million poly scene in the past!
Ovidiu Enache
Hi Martin! The first scene has 32.647.560 triangles and the second one has 34.526.848 triangles . Thanks !
Speedster
The highest poly count I've run so far is 96 million, and with no problems.  Of course the initial SolidWorks import took about an hour!  I'm running 32 cores.
As to your renders- you guys have all the fun!  Great job!!
TpwUK
Ah yes Bill, the locomotive scene, over ab hour to import and rendered in 20 minutes or so - Still makes me smirk, thinking about how it would make feel - permission to PM you regarding your work ?
Ovidiu Enache
#10
Quote from: TpwUK on November 02, 2013, 04:44:43 PM
Yes, of course . Thanks!
ironconquest86
Wow! amazing creatures, your renders look great!
btw are you tweaking the render passes fom keyshot ?
Raul
Ovidiu Enache
Thank you! Yes the renders are tweaked in post for better integration with the background and to give them the desired atmosphere. I've used only the clown pass.
GregHurley
Great texturing, I like the overall variation you created.
