Author Topic: animation module is much less reactive under Mavericks  (Read 3687 times)
Offline fario
  • Total likes: 0
  • www.mrconcepts.ch - industrial design and render
    • industrial design
« on: November 05, 2013, 01:43:14 am »
hello,
I see the animation module is much less reactive under Mavericks.
MacOS 10.9
Especially when I move the cursor on the timeline with the mouse, the reaction time of my scene in the window rendering, cursor, etc is much slower than in Mountain Lion.
Have you noticed the same problem?
Thank you.
Antoine
« Last Edit: November 06, 2013, 12:07:58 am by Antoine »
Offline fario
  • Total likes: 0
    • industrial design
Re: animation module is much less reactive under Mavericks
« Reply #1 on: November 05, 2013, 06:08:04 am »
is it possible to have a response by Luxion quickly please?
thank you very much.  :)
Antoine
Offline richardfunnell
« Reply #2 on: November 05, 2013, 06:32:43 am »
One suggestion I would make is to disable App Nap, I've found that helps my realtime performance.
You can adjust this by going to your Applications folder, selecting KeyShot4, and select "Get Info" by right-clicking on the application.
Offline fario
  • Total likes: 0
    • industrial design
« Reply #3 on: November 05, 2013, 06:46:24 am »
thank you for your suggestion :)
I found!! must be booked minimum 1 core for the Mavericks system, if it does not have enough resources to remain fluid.
In the preferences of v.4.2, you can choose the number of cores dedicated to Keyshot.
In any case it's better now.
Antoine
« Last Edit: November 06, 2013, 12:08:20 am by Antoine »
Offline fario
  • Total likes: 0
    • industrial design
« Reply #4 on: November 05, 2013, 06:53:37 am »
I'll try disabling App Nap on my Logitech software also ... :)
My M 705 has become unusable since Mavericks.
« Reply #5 on: November 05, 2013, 09:10:03 am »
Here's a fix for that, I struggled with the same issue :)
http://forums.macrumors.com/showthread.php?t=1604905
Offline fario
  • Total likes: 0
    • industrial design
« Reply #6 on: November 06, 2013, 12:32:43 am »
thank you Richard! :)
