What is happening with my render?
Started by J.LUCAS, November 14, 2013, 06:33:55 AM
J.LUCAS
  Hi all, I have been trying to render in Keyshot 4 with the PRO E plugin and this has happened ( see image), not sure what is going on.
However in keyshot 3 the same render is fine. Any one have an idea what all the black is and the reflections?
Sorry that I can not show the whole image as its a new project for a client.
Is this rendering using realtime, max time, advanced control? Or do the spots happen regardless?
Chad
J.LUCAS
Hi Chad
Using the advanced control the spots appear, however using maximum time it seems to be fine.
What would cause the spots in maximum time, out of interest?
Jason
Thanks for the feedback, Jason. I was trying to narrow it down to see what it could be. I'm pretty sure this was a bug that has been recently fixed. To be sure, would you care to share your model? It will be used for testing purposes only. If so, please use this upload link: https://keyshot.wetransfer.com/ and send to support@luxion.com
Thanks,
Chad
J.LUCAS
Thanks Chad
Unfortunately I can not share the model due to client confidentiality.
Thank you any way for your feed back.
Jason
