Myler material (non-perfect chrome)
Started by Pepster3D, November 26, 2013, 06:26:19 AM
Pepster3D
Hiya,
I need to create (today!) a building covered in a myler type material.  It will be like reflective chrome but with a non-perfect surface with a little bit of warped reflection.  Any chance of doing this in Keyshot?  Or do you think I need to add some noise to my model before importing into keyshot?  I was hoping to alter it in the material itself.
Thanks,
Darlene O.
I would start off with a smooth chrome (adjust color, if needed) and then use a noise texture (under procedurals) and scale the bump height and overall texture scale to your liking. Here's what I ended up with (after a very quick shot at it):
Pepster3D
Yeah, that looks good!  So you put the noise texture in your bump map only?
And if that's too smooth, just add a little roughness under the chrome's properties (and a maybe bump the samples up a bit under the roughness slider (click the little arrow)). Here the same image with a little roughness applied:
Quote from: Pepster3D on November 26, 2013, 06:54:18 AM
Thanks! Right, just used the procedural "Noise (Texture)" option under the bump and cranked up the scale of each to give it a wavy look. And the latest image, I bumped up the roughness option under the materials properties to create a little less reflective look. Let me know if you need the BIP file or anything.
Pepster3D
