Trex 900 Nitro
Started by Barbarian, January 01, 2014, 09:50:02 AM
Barbarian
Solidworks model. test render but for some reason I keep getting washout color on some of the parts. The Blade assembly especially. why does this happen?
thomasteger
Because the light is hitting it. Try a different HDRI.
Barbarian
light is hitting the muffler too but its giving nice effect other parts is washing the color off
feher
Quote from: Barbarian on January 02, 2014, 12:10:46 PM
The muffler is a different shape so it will reflect light differently then a flat surface like your blade . A flat surface does not have fall off like a round surface.  So the blade will show brighter in the light. Tweak the blade material so it does not blow out. If the blade material is linked to another part unlink it so you can just tweak the blade material without affecting the other parts.
Without the KSP it is hard pin point exactly what is going on or what you are trying to do.
My door is always open if you need some help.
Tim
Barbarian
here is my problem the blade I understand it isnt a real problem. You see the colored controls the light is washing off the color the reflections are not that strong
I run on the same issue on previous renders.
Is the problem with the material should it be darker color is the HDRI that is causing the wash off, Is it the soft transitions in the HDRI light to dark that give off this wash off effect?
thanx tim much appreciated
Ah...  Anodized material can be tough to deal with.  I suggest you try a metallic paint, and play with the flake color and size, etc.  I think you will find less washout.
