Strange Shadowing
Started by JAKiii, January 08, 2014, 07:58:31 PM
thomasteger
Yes - correct. Hidden surfaces should no longer come through. We will have another look.
br3ttman
Thomas,
I got the SolidWorks plug-in and, yes, it's so much better to push files from SolidWorks than pull them into KeyShot using the "beta" importer!!!  Quilts are better tessellated, don't have cracks in the seams, and hidden surfaces stay hidden!  I still need to play with "live linking".
thomasteger
We actually discovered that an old bug snuck back in with the BETA importer. Will be fixed.
powder3D
Back on topic:
I got the same problem since the version 4.3 as you can see.
I'm working with 4.2 again now which is fine.
MacBook Pro-User
guest81576
I am getting the same shadow noise problem on my renders—real time aking looks fine. Why would advanced tab become so problematic and touchy? I seems to make no difference how high I make the settings...
help.
Much appreciated,
Dimitry
thomasteger
Uncheck the "Global illumination cache" and you won't see these issues. Once unchecked, it will stay unchecked. Make sure to use 4.3.18.
