Author Topic: Network render too bright  (Read 5840 times)
Offline 3D Off the Page
« on: March 09, 2014, 05:33:21 pm »
I am rendering an image on our render farm and when it is completed it is very bright and washed out compared to the same image rendered on the desktop.
thomasteger
Re: Network render too bright
« Reply #1 on: March 10, 2014, 05:28:13 am »
It is difficult to say what the problem is. Can you share the scene?
Make sure you are running the latest version of KeyShot NR.
« Reply #2 on: March 11, 2014, 07:03:30 am »
I am running the latest version of Keyshot both on the desktop and render farm.  Attached are examples of what has been run on the the desktop and network rendered.  I can send you the ksp file if needed.
thomasteger
« Reply #3 on: March 11, 2014, 07:10:44 am »
Please do - send to [email protected]
Thanks!
« Reply #4 on: March 11, 2014, 07:14:01 am »
Thomas, just sent an email with the file.
« Reply #5 on: March 11, 2014, 03:13:33 pm »
Figured it out.  I had to change the file locations to a blank file on my desktop versus the KeyShot folder.  The network render must have been grabbing some of the default environment or light settings.
thomasteger
« Reply #6 on: March 11, 2014, 03:39:28 pm »
Good to know. Thanks for the update.
Offline Will Gibbons
« Reply #7 on: June 02, 2014, 07:23:31 am »
Hey, sseager,
I'm having a lighting issue of my own : https://www.keyshot.com/forum/index.php/topic,8365.0.html and judging by what you said... I wonder if this could be happening to me where when I process the queue, it grabs some other environment settings and doesn't use my custom HDRI.
Have you ever seen something similar?
Thanks.
« Reply #8 on: June 03, 2014, 08:02:45 am »
Figured I'd mention that I resolved my issue and it's because of your findings. The HDRZ file I created and was using wasn't in one of Keyshot's default environment folders. Once I moved it there, saved and refreshed it, all was well.
