Archive for older plugins?
Started by dsgdan, September 02, 2010, 08:16:16 AM
dsgdan
I have just moved my KeyShot 64 1.9.54 to a new Windows 7 64-bit computer, and it is working fine.  I have downloaded the Pro/E plugin and installed, but when I press the render button in Pro/E, I can select orientation and resolution options but Keyshot does not start.  I think the plugin I downloaded is for KeyShot2.  Is there an archive where I can download a plugin for 1.9?
____________________________________________________
I have uninstalled KeyShot 1.9 and the Pro/E plugins, and then re-installed KeyShot 1.9 first and the plugins second, and everything is working fine.  I think that a registry setting that starts KeyShot must have had an error and the re-install has corrected it.
Brian Townsend
Yes the plugins will work for KeyShot 1.9 and 2.0.  Glad to hear you are up and running!
Brian
