Summer is here... Have a Coke!
Started by Hellboy1991, April 20, 2014, 08:23:06 PM
Hellboy1991
Something I Built on Wings3D and Rhino . Then added color maps(the sticker) , and the classic Coke 'Green' glass....
Certainly your best render so far - Well done :)
Which bit was Wings Responsible for ?
Hellboy1991
Thanks martin!  :D
... Those ridges on the sides were made in wings ...
Just couldnt get them to look right in Rhino  ;) !
... Presently trying to 'Fill' some Coke into the Bottle...  :o
Same way as fluid in a glass .... In Rhino. extract an iso curve on the inside surface of your bottle, use it to create a planar disc surface. Above the disc remain as glass with a 1 or 2mm blend/fillet where the glass and disc touch. All the remaining internal glass below the disc is then assigned a new layer ready to become coke. The fillet/blend needs a layer of its own too because its a slightly different colour from the glass and the coke.
If you have some coke there with you, pour some into a glass and study it, especially at the point where coke meets glass.
Hellboy1991
Thats a great tip, Martin...  :) Thanks!
thomasteger
Looks really great. Great glass material.
Hellboy1991
Thanks :-) ... its double-sided with a refractive index of around 2.5, and a light green tinge...  ;)
