Author Topic: Testing Architectural Render  (Read 6006 times)
Offline ben10
« on: September 08, 2010, 09:38:25 am »
here's another exercise with keyshot in architectural field
Offline JeffM
Re: Testing Architectural Render
« Reply #1 on: September 08, 2010, 10:20:57 am »
Very nice
Offline magnumpi
« Reply #2 on: September 08, 2010, 11:52:04 pm »
This is one thing where keyshot is still a bit weak in my opinion. I do use it for rendering exhibitions stands which is kind of architectural and as those don't have to be super realistic it works awesome for me (a lot faster than 3d max as I don't have to bother with lights and results are good) but for anything more serious it still needs some improvements. I am sure it will get there eventually as KS team does impressive things to this "little" program. Maybe there could be something similar to keyshot but made specifically for arch. exterior and interior rendering. Same bullet fast but different interface, cameras, additional lights etc which would produce realistic images.
« Last Edit: September 08, 2010, 11:56:39 pm by magnumpi »
Offline KeyShot
« Reply #3 on: September 09, 2010, 02:43:46 am »
You are right magnumpi. We do have something planned that will address architectural lighting. Under the hood we already support all the different lights including ies lights, sky lights, spot lights, area lights etc. All we need to do is figure out how to best expose them inside KeyShot.
-- Henrik
Offline ben10
« Reply #4 on: September 10, 2010, 10:07:53 am »
one certainly locking in this is sss....i know it will be available in 2.1
Offline ben10
« Reply #5 on: September 10, 2010, 10:10:17 am »
one thing that is fast in keyshot is material creatiion and light setup and that's it...it's unbeatable in speed just few clicks and you have nice materials....btw i've used realtime render in here not the offline render...any news on saving screenshot in high res?
Offline KeyShot
« Reply #6 on: September 10, 2010, 03:46:28 pm »
Yes, 2.1 will also support using the realtime renderer for offline rendering at any given resolution. This guarantees that the rendered image matches the realtime output.
-- Henrik
Offline Richman
« Reply #7 on: September 11, 2010, 11:48:27 pm »
-Henrik
Roll out these hidden under the hood features.   We are itching to get our hands on them.  Or even beta test them.
Best,
Josh
Offline KeyShot
« Reply #8 on: September 12, 2010, 04:36:32 am »
Josh,
We will do that ;) We are being careful not to make KeyShot too confusing by adding too many options in the interface. That being said we have a lot of new developments in the pipeline...
-- Henrik
Offline jbeau
« Reply #9 on: September 13, 2010, 10:15:42 pm »
Heard through the grapevine that something was brewing. Any timelines on this? Need a beta tester? If got tons of photorealistic datasets ready to be plugged in.
Offline Richman
« Reply #10 on: September 14, 2010, 02:35:55 am »
If you need a beta tester.  At your service! Count me in ;D
