Quick Carbon Fiber Test
Started by JeffM, September 14, 2010, 01:45:40 PM
JeffM
Straight out of KS using a trick with labels to create a smooth clearcoat over the bump :)
Richman
Very cool.  You gotta tell us the trick used here.
epoxid
So what is the trick? Can you Please, tell as the tip.
10X!
JeffM
#4
This trick can be done in 2.1 by using a white, semi transparent, image as a label, then you just crank up the specular color to white and increase the IOR of the label until you get the desired amount of shine on the surface.
You will also want to set the label to "repeat" and use box mapping to make sure it covers the entire surface.
The white image will tend to cast a light color over the surface as well. You can reduce the intensity of the label to get rid of this white cast.
You can download a sample scene here: http://www.keyshot.com/downloads/scenes/bip_CarbonRing.zip
epoxid
10X !! I'll experiment with materials considering your advices.
keisuh
ambarbandi
Great Tip...I will use it in my next product render  ;)
Barbarian
can you reupload the scene very nice results im interested in seeing how you set it up
Millergo
Millergo
Jeff please I need that Material..............OMFG where you found that texture?....
thomasteger
Download from the links above.
Millergo
Quote from: Thomas Teger on January 31, 2014, 06:20:52 AM
I cant download fron the second link :S
DriesV
Josh3D
