Author Topic: Any tutorials on how to get good gold colors?  (Read 6394 times)
Offline keyshnoob
« on: September 15, 2014, 09:37:24 pm »
Hi all,
I find the gold colors quite unrealistic and unappealing.
Does anyone know of tutorials to get nice looking gold colors?
Offline Invertex
Re: Any tutorials on how to get good gold colors?
« Reply #1 on: September 16, 2014, 02:21:22 am »
Surface imperfections and dirt/grime go a long way to helping make metals look believable, as well as a good environment to reflect. Here's a gold material I whipped up that allows you to blend in a "grime" texture in a sense. It's a modification of one of the "old metal" shaders.
Right side is this shader, left is the default 24K Gold.
Some KLK action :)
You can play with the "Blend with Color" as well as the "Brightness" & "Contrast" in the texture tab to get the color and look you want.
Shader file is attached.
Offline fario
  • Total likes: 0
  • www.mrconcepts.ch - industrial design and render
    • industrial design
« Reply #2 on: September 16, 2014, 06:58:39 am »
thank you for your help.
but... Warning!
your .mtl file is corrupt.
At home, he crash KeyShot 4 and 5
Antoine
Offline jhiker
« Reply #3 on: September 16, 2014, 07:02:33 am »
It didn't crash my Keyshot v5.
Thanks for sharing.
Offline Invertex
« Reply #4 on: September 16, 2014, 01:11:33 pm »
Nice renders jhiker, looks good.
but... Warning!
Is your Keyshot 5 up to date? I don't have Keyshot 4 to test it with. Perhaps your download was simply corrupted? Try downloading again and see if it works. Or make sure you're running Keyshot in Administrator mode, you should be for general usage. If not, here it is on pastebin instead, in case it's a file permissions issue.
http://pastebin.com/raw.php?i=QRWutvqh
« Last Edit: September 16, 2014, 01:13:26 pm by Invertex »
Offline Invertex
« Reply #5 on: September 17, 2014, 12:40:39 pm »
I've uploaded the material to the Keyshot Cloud as well.
Offline remson69
« Reply #6 on: September 22, 2014, 12:46:51 pm »
This material crashes my KS4 too, just hangs when I try to import. Can anyone verify compatibility with KS4 or produce a compatible version?
Great Gold effect btw :)
Offline Invertex
« Reply #7 on: September 22, 2014, 04:55:26 pm »
Unfortunately, Keyshot 4 does not have the material I used as a base for this, and I don't think the material system in Keyshot 4 has the capability for it. Might be time to upgrade to 5? ;)
Offline remson69
« Reply #8 on: September 23, 2014, 10:47:39 am »
That's a shame, but thanks for looking into it!
I'll just have to wait till I get KS5 :D
