Author Topic: texture mapping Ivy leaves?  (Read 3811 times)
Offline hugo
« on: October 19, 2014, 11:44:15 am »
I'm sure this is not the first time this issue has been raise, and searching did not turn up any results. :-[
What do I do in KS to render the ivy leaves correctly from Ivy grower ?
TIA!
Offline edwardo
Re: texture mapping Ivy leaves?
« Reply #1 on: October 19, 2014, 11:47:56 am »
use the "UV" mapping setting. you may have to set the X and Y coords to 0.5
Ed
Offline hugo
« Reply #2 on: October 19, 2014, 11:51:40 am »
WOW ! that was fast,....... thanks!
I had forgotten to post the pic, so now I wont have too 8)
Offline hugo
« Reply #3 on: October 20, 2014, 07:35:31 am »
I spoke to soon :( ... I'm still struggling.... How do I eliminate the white background the leaves sit on?
« Last Edit: October 20, 2014, 09:57:14 am by hugo »
Offline richardfunnell
« Reply #4 on: October 20, 2014, 12:43:16 pm »
Make sure you check "Use Diffuse Map Alpha" which will clip the geometry based off the color texture alpha channel. This should give you the effect you're looking for as long as the leaf texture has the alpha channel in place.
