KS5.1 Beta UI/Graphical issue
Started by stefan.re, October 29, 2014, 12:46:11 PM
stefan.re
Hey guys,
After having lots of problems on my retina MBP I thought the solution is here with the update to KS 5.1 but now my KS window looks like the attached screenshot. A white overlay on the top left corner that stays in place whatever I do.
Is there a fix for that?
Thank you!
BTW: Your forums don't work on the latest version of Safari on a Mac.
finkster
I had the same issue, one day the white overlaid box magically disappeared again without any rhyme or reason. One of the 10 or so things that just don't work in KS5.1 beta.
richardfunnell
Enable/disable the ribbon by hitting the R key on your keyboard and see if that makes it disappear.
edwardo
QuoteEnable/disable the ribbon by hitting the R key on your keyboard and see if that makes it disappear.
do the same with the toolbar at the bottom (T)
akiefer
Hitting the 'R' buttorn solved it for me...
skot
Having the exact same issue as the screenshot with the KS 5.1 released this morning. I ended up just toggling the ribbon and the tool bar on and off till it eventually went away.
