Alias file import problems
Started by epoxid, October 03, 2010, 12:25:45 AM
Thanks Brian!
You won't have this problem on the Mac btw because it is all 64bit.
murtyatvur
Woohoooo !!
I did exactly like epoxid's way
by default Alias created this PATH on my computer C:\Program Files\Autodesk\Alias2010\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\Autodesk\Backburner\;C:\Program Files\Common Files\Autodesk Shared\
and I created a new path called ALIAS_LOCATION and directed it to C:\Program Files\Autodesk\Alias2010\bin
then I removed the 64 bit wire folder from keyshot ...
The importing takes a bit time but the tumbling and zooming inside the space even with a complex wire is flawless ...
Thanks a lot guys !!!
Great - it takes some time because it has to go through the tessellation process.
JAKiii
This worked for me, Thanks Thomas for this translator -
Jamie
You're welcome! Let us know if there are any issues. Since we are an Autodesk Development Partner we have direct access to the dev team.
We will fix the little glitch with respect to the installation in the next update.
cqw.tony
i also have this problem!!
thanks Thomas!! really!
Have you upgraded to the latest version?
