Author Topic: KeyShot for ZBrush Installation  (Read 42944 times)
Offline akiefer
Re: KeyShot for ZBrush Installation
« Reply #15 on: February 02, 2015, 03:41:29 am »
THANKS 1vezsy! That was exactly it! The settings in Keyshot to activate live linking was not checked.
I am happy now ;-)
Albert
Offline Chad Holton
« Reply #16 on: February 02, 2015, 03:43:20 am »
You can install it on 2 computers, but can only have one activation at a time. You can easily transfer the license between the 2 installations.
What is the process for transferring the license between the 2 installations?
Please make sure both machines are hooked up to the internet first.
1. On your old system, go to Help/KeyShot>>About and write down your
serial code.
2. Go to File>Deactivate license. That will free up your license.
3. On your new system, you'll just need to run KeyShot, fill in the form
and your serial code.
It should be able to then automatically activate, but should it fail, you
can create a license request file to send to us for manual activation.
Offline bisenberger
« Reply #17 on: February 02, 2015, 06:16:23 am »
Thanks Chad
Offline celso
« Reply #18 on: February 02, 2015, 07:34:05 am »
I bought keyshot for zbrush yesterday but I am still a bit confused.
On the page it says, "all keyshot features".
But I am having a hard time finding the render passes (layers) and the hdr editor. so... are those features not included? am I missing something ?
I am trying to find it on the documentation but as far as I can tell  it does not specify what should be on the keyshot for zbrush.
Offline Josh3D
« Reply #19 on: February 02, 2015, 08:39:12 am »
Hi Celso. It includes all features for KeyShot HD, so passes and HDR Editor are not included.
Offline celso
« Reply #20 on: February 02, 2015, 08:52:48 am »
Thanks Josh.
I just think this should be more clear.
When it says:
"All KeyShot features, including material and lighting presets"
Is a bit misleading.
I wish at least the passes were available. not having it made me regret buying it.
(its my fault, I could have used the trial version first)
Offline 1vezsy
« Reply #21 on: February 02, 2015, 10:10:58 am »
I am happy now ;-)
Albert
you are welcome, totally know the feeling  :)
Offline bisenberger
« Reply #22 on: February 02, 2015, 10:39:23 am »
KeyShot for ZBrush and ZBrush to KeyShot Bridge are super cool!  8)
Great combination, Thanks Pixologic and Luxion
Offline Artbot
« Reply #23 on: February 04, 2015, 03:36:58 pm »
going to system preferences --> security and privacy--> general look for allow apps downloaded from and change it to anywhere...
This did it! Thanks. I was able to open the extra content!
Offline Dylan
« Reply #24 on: February 05, 2015, 12:24:31 am »
I just want to say thanks to Luxion for Keyshot for ZBrush. I know a lot of work went into this.
As one of those who tested the excellent ZBrush/Keyshot 4 Goz beta, the Bridge system is miles better and is what many of us wanted for a long time.
Thanks again lads.
« Reply #25 on: February 05, 2015, 04:23:14 am »
Thanks for the kind words, Dylan.
Offline namrettek
« Reply #26 on: February 05, 2015, 06:45:49 am »
I'm loving Keyshot for Zbrush!
Did have a couple of questions if anyone could help out.
1.  Can you render over 72 dpi?  I set it to 300 DPI but the psd file I got was 72.
2.  When I rendered with transparency I only got my model and a transparent BG.  Where is the BG plate?  I couldn't find it.  Does transparency render leave off the BG picture completely?
« Reply #27 on: February 05, 2015, 06:49:13 am »
@1. The output file is always 72dpi. You will need to change it in PS.
@2. Yes.
Offline namrettek
« Reply #28 on: February 05, 2015, 07:07:06 am »
Thanks for your answers.
Ok so the DPI is just sort of a calculator so you know what it would be in print res?
« Reply #29 on: February 05, 2015, 08:29:06 am »
Yup - exactly. We are looking at adding the ability to render out at the set DPI resolution in KeyShot 6.
