Hello.
I am trying to get the plexiglas material right. This is the best i can do, but its not accurate enough. I am using Solid Glass with IOR 2.38. Does anyone have a better material...
TNX
(http://postimage.org/image/1yuy3xbfo/)
I suggest using the Gem or Dielectric materials. You want control over the Abbe number. The Abbe number gives you the dispersion that you see in plexiglass.
Use the following settings:
IOR - 1.5 - 1.51
Abbe - 34
Increase your raybounces in the realtime tab (12 should be enough), and turn on "detailed indirect illumination".
I found these numbers on the internet.
Hope this helps.
Thomas
Thanks for a quick reply. It get better. Still i get the black edges, and the color is white...
(http://postimage.org/image/2dvk418ec/)
I am trying to make sompting like this ...
(http://postimage.org/image/2e17j4x50/)
Increase your raybounces. It also depends on your lighting.
They are at 32... :-\
Change your light settings similar to your original.
The reflections of the blueish Background is what you see.
I try that too. Blue is just a backround color, enviroment is pure white HDR file...
32 raybounces
detailed indirect illumination checked
default HDRI lighting
Ground shadows turned off
Gem material - IOR 1.51, Abbe 34
The dark reflections you see is from the reflection of the environment.
How's that?
:) ... U sure showed me ... :) .
Thanks a million ... ;D
Glad to hear it helped!!
It seams that problem is not solved. Sendig the example...
(http://postimage.org/image/1i4zq4sdg/)
Here is the link to a file. If someone can get it right, i wold like to see it... :)
http://www.sendspace.com/file/z0ux5x
Depending on the angle you view your model at, 32 ray bounces may not be enough to illuminate all the edges. Try outputting a render with the bounces set to 64.
;D , ;D
Thank you ALL... I O U 1 ... ;)
(http://postimage.org/image/1vqr2jp2c/)
Looks great! I'm glad we could help :)
