Yoghurt plastic lid (simple question)
Started by zooropa, January 09, 2018, 04:18:26 AM
zooropa
Hi. I need to do a render of a yoghurt product. I am modeling in Rhino. As some of you know Rh is not the best when it comes to " thicken " a surface.
I wanted to know if KS will manage to make a realistic plastic with a surface that is double sided. I am in the modeling process and if you tell me that the surfaces needs to have certain thickness I will model it differently.
Please find attached an example (the design is not the same). I gues is polypropylene plastic.
Thanks a lot.
Robb63
In Rhino I would do the thicken (offset) before adding the corner fillets. Then add them after.
Helps a lot with adding thickness and shelling
Esben Oxholm
For the most realistic outcome, I would suggest you to model the correct thickness.
Cheers,
zooropa
Quote from: Robb63 on January 09, 2018, 08:03:56 AM
Great tip ;)
zooropa
Quote from: Esben Oxholm on January 09, 2018, 08:09:41 AM
Cheers,
Worked! Takkk
