Need advice to pick color Wood (Advanced)
Started by travis.designer.vn, June 21, 2022, 04:58:02 AM
travis.designer.vn
Hi
I try to replicate color of real wood.
First I google Ash Wood photo. Then I pick color from photo But it look not good.
Need advice to pick color.
Attached real ash wood photo
Thank
Travis
travis.designer.vn
Hi
Are there any suggest to control these colors:
Thank
Travis
Anindo Ghosh
Please see if this comes reasonably close to what you need. KSP is attached, you can find the colors there - and tweak them to your satisfaction.
Possible issues you may have faced:
1. Eyedropper color picking is imprecise when the source (your reference photo) has many colors close to each other.
2. If the reference you are color-picking from is open in a separate application, potentially in a different color space, what gets picked up is not what you saw. I added your reference as a frontplate to the KeyShot render and color-picked in-app.
3. Even with a good color pick, some manual tweaking is needed to get the perceived patterns to look similar to reference.
4. Organic and noise-based textures are difficult to achieve a perceptual match with.
5. Lighting. Of your render, as opposed to your reference.
travis.designer.vn
Thank @Anindo Ghosh
I think import reference image into Keyshot is the most important step. As you said It help to pick precise color.
