Small Viewport Issue
Started by lazer, January 05, 2014, 06:21:39 AM
lazer
Hi All
Not sure why this has happened, the viewport has reduced in size and I cannot enlarge it making it difficult to render in such a small view.
Using Keyshot 4.3 on win 7.
I have tried full screen and it does not work, It was working fine  from install then after a few weeks I get this problem, I also think this happened around the time of the last update.
Any help would be great, searched the forum for viewport size issues and did not find an answer.
The only work around I can think of is to uninstall and reinstall?
Claus Jensen
This is because you have either "Lock Aspect" or "Lock Resolution" checked in the Project -> Settings.
These values are now saved between sessions.
lazer
Yes that fixed it!  thanks Claus I do remember ticking these on my last project asI was playing with settings. Cheers
