plugin for MoI 3D
Started by Finema, February 21, 2015, 12:56:32 AM
Finema
it will great to have a plugin for MoI 3D... (mac/pc)
http://moi3d.com
Why do you need a plugin ? Keyshot's 3DM import works perfectly fine on OS X and Windows :)
Finema
a plugin in MoI to export and update geometry directly
Finema
more clearly >
LiveLinkingTM
Luxion's LiveLinking technology takes the KeyShot plugin to the next level. With LiveLinking, your modeling application and KeyShot are connected. With it, you can continue to work in the 3D modeling application after the initial transfer to KeyShot. At any point in time you can update your designs in KeyShot with the simple push of a button. Only the changed parts and layers will be transferred to KeyShot, without the loss of any materials, animations, lighting nor camera setup. Simply put, everything will be maintained. Do this today, tomorrow or next week. All you do is open your model in the 3D modeling software and the scene in KeyShot – and you are live linked!
Applications and plugins that currently support LiveLinking:
Autodesk Fusion 360
IronCAD
PTC Creo & Pro/ENGINEER
Rhinoceros
Siemens Solid Edge
solidThinking Evolve
Dassault Systemes SolidWorks
Pixologic ZBrush
and it will great to add MOI 3D !
thanks
There is a script that is being developed on the MoI forum for doing this, but it's waiting for a Mac port (if you're up to it, I wish i had the time to get involved). You can do essentially the same with the 'Update geometry' option when importing 3DM, it's a few more clicks of a mouse but it does the same as the plugin and is easier to support when things goof up as they inevitably do when working with 3D.
Finema
