KeyShot 5.2.10 and SolidEdge Files (Crash)
Started by FernandoRocker, March 11, 2015, 03:48:27 AM
FernandoRocker
Hello.
My company just bought me a license for KeyShot. The version I downloaded was KeyShot HD x64 5.2.10
I'm using KeyShot to render SolidEdge files that the engineers here at work design in SolidEdge. I use those renders for publicity and stuff like that.
The files I'm using are SolidEdge parts (.par) and assemblies (.asm)... but everytime I try to open/import any of those files, the software crashes and it gives this error.
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   keyshot5.exe
  Application Version:   5.2.10.0
  Application Timestamp:   54e59e66
  Fault Module Name:   Qt5Widgets.dll
  Fault Module Version:   5.4.0.0
  Fault Module Timestamp:   54b54107
  Exception Code:   c0000005
  Exception Offset:   0000000000049280
  OS Version:   6.1.7601.2.1.0.256.48
  Locale ID:   1033
  Additional Information 1:   e9f7
  Additional Information 2:   e9f707caeb489eb4cfdb784d88202a9c
  Additional Information 3:   881a
  Additional Information 4:   881a08fd60b8a28dc04c571c3aae594b
Before version 5.2.10 I was using the trial version 5.1.66 and I didn't have any problems. I could open the SolidEdge files just fine.
Help, please! It is urgent.
We just paid $1000 for a useless software.
MisterNeil
#1
Hello FernandoRocker,
If you don't get a quick response to your question from this forum, I suggest you call KeyShot's tech support numbers ASAP:
1 (949) 274-8871 x222 or 1 (949) 274-8871 x304
Keep in mind, their office is in California, USA. I hope you get your problem resolved.
Neil
jeffw
Hard to know what is going on without more information.
Which version of SolidEdge are you running? I am guessing an older version if you need the stand alone KeyShot. SolidEdge now has keyShot embedded as its default renderer.
How are you getting your files to KeyShot? What format are you using?
KeyShot is not "embedded" inside Solid Edge. It is the default renderer with ST7, but still a standalone application.
jeffw
Perhaps you could elaborate on this. My company is under the impression that they now longer need the stand alone KeyShot since it is the default renderer in SolidEdge. I was told by it think it was Garret at KeyShot that we can de-active the stand alone KeyShot and work exclusively in SolidEdge. Is this not the case?
KeyShot remains a standalone application, even if get KeyShot as part of Solid Edge. This version is called KeyShot for Solid Edge. Again, it is NOT inside Solid Edge.
KeyShot for Solid Edge is tied to the Solid Edge license such that it can't run on a different computer. Also, it can only import data through Solid Edge and the plugin that comes with Solid Edge. It is up to you whether you think this fits your needs.
I hope this explains it.
