Author Topic: Vein model not seen under translucent skin material. why?  (Read 4491 times)
Offline davecardwell
« on: October 27, 2010, 05:12:41 pm »
How come I can't get my 3d model of a vein to show up through the surface when I use the translucent material and a skin mesh? I would expect to see the shadow of the vein model when a light is behind my skin object and my vein mesh is just inside the skin model. No matter how high I turn up the translucency I can't see the vein.
Any ideas?
  • Guest
Re: Vein model not seen under translucent skin material. why?
« Reply #1 on: October 29, 2010, 01:00:44 pm »
Not sure - this is a question for the scientist. Henrik?
Offline KeyShot
« Reply #2 on: October 30, 2010, 07:31:23 am »
It is correct that the translucent material will not show objects behind it. You may want to try a transparent material with surface roughness in this case.
-- Henrik
Offline quigley
« Reply #3 on: November 26, 2010, 06:11:43 am »
Ah! That explains why my polypropylene medical containers with green medicine are rendering opaque!!! Can I make a suggestion. Do you think we could have a series of Webinars or pdfs detailing how to create materials for commonly used product design needs such as:
1. Polypropylene containers - showing contents
2. Creating different types of liquids (from water to slush)
3. Speckled plastic (or plastic with additives to get a speckled effect)
Offline jhiker
« Reply #4 on: November 26, 2010, 07:24:12 am »
You mean like a glass-filled nylon - I'd like that too..
  • Guest
« Reply #5 on: November 26, 2010, 10:47:00 pm »
The next webinar will focus on material creation. And for "milky plastics" you want to use the advanced material with the advanced settings shown, using Roughness Transmission. The translucent material won't get you there.
