Author Topic: .wire and obj  (Read 8664 times)
Offline dmarek
.wire and obj
« on: May 04, 2015, 07:42:08 am »
Hopefully this is a simple solution -I am just not able to figure it out. When I import a wire file that contains obj's they do not import in the same position-size. I have tried to do separate files with the obj only but the obj layers still has to be scaled or moved? is their a setting that will accommodate this. It seems that I used to be able to do this...
Offline TpwUK
Re: .wire and obj
« Reply #1 on: May 04, 2015, 10:06:44 am »
Use Add To Scene, Location = Keep Original,  and set Same scale as last import from the Import Dialog
Offline dmarek
Re: .wire and obj
« Reply #2 on: May 05, 2015, 06:56:23 am »
Thanks Martin, however I had tried this and the .obj items come into Keyshot at different scale and in some instance different orientation. Perhaps it is something in ALIAS that I need to do. I can move them int the correct position but it seems like uneccessary steps.
Dave
  • Guest
Re: .wire and obj
« Reply #3 on: May 05, 2015, 09:18:22 am »
Can you share the file so we can take a look?
You can send directly to [email protected] Use keyshot.wetransfer.com to get larger files to me.
Thanks,
Thomas
Offline dmarek
Re: .wire and obj
« Reply #4 on: May 05, 2015, 11:59:08 am »
will do
