Best way to render a 2 sided label on a glass bottle
Started by ldichiara, May 09, 2015, 11:04:50 AM
ldichiara
Hi Guys -
I have to wrap a label around a bottle and was wondering the best way to approach doing it. It consists of a clear label with artwork on it that wraps around a liquor bottle - if you are familiar with grey goose, for example it is that type of effect, where i am wrapping the label so the artwork appears on the front of the bottle and if you look through the liquid you can see the back label are.
The bottles are not all completely true cylinders - they have slight contours to them so not sure how big of an issue this would be.
In the past I have had some challenges the getting the decals to map correctly. Going to try using the 'cylinder' setting and see what it yields.
Any advice would be appreciated.
Thank you.
L
Handpiece Headquarters
Maybe create a plane where the label will be in your 3D program and then apply a label to each side of the plane in keyshot
