Finally dirt & grime for the CAD folks!
Started by DriesV, May 19, 2015, 12:30:29 PM
DriesV
Okay, the nodal material system is seriously awesome...
Endless possibilities to add subtle (and less subtle) shading variations to CAD geometry. Nodal materials and procedural textures are a killer combo!
The Material Graph is actually a lot of fun to use.
Just scratching the surface. Pun intended.
TpwUK
Most complex node graph i have seen thus far Dries :)
Great looking result too
DriesV
Thanks, guys!
This shot shows the materials a little better.
DriesV
OK, so here's a final shot with just HDRI. Thought the physical light artifacts were a bit distracting. ;)
Esben Oxholm
Nice. Although some funny stuff are happening at some of the edges, it looks quite cool. Good job!
soren
Can I ask what settings you used for the color randomize node? Just curios to see how well the node works. I primarily added it to support random color variation on curves (where it can add a random color change on a per curve basis), but always nice to see it used for other things :).
Søren
Despot
Wonderful Dries, I knew the Material editor would be right down your alley...I know what question I'd like to ask though  ;)
J
DriesV
Quote from: soren on May 20, 2015, 12:27:00 AM
Søren
Søren,
I pretty much used the standard settings. I attached a rendering where I disabled the curvature opacity texture for the Plastic material (see Material Graph above).
The result is a bunch of a sharp edged facets. Not very elegant as a standalone texture, but it works quite well to introduce some subtle tonal/... variation in the 'rust' patches.
Maybe the color randomize node can be improved to have blurred facets? ;)
soren
Ahh I see. The facets are the mesh triangles. I think what you need is procedural like camouflage but with more control over the patch size, shape and color, correct? That is much easier to blur as well. I will add this to the todo-list for 6.1.
I expect to change the color randomize to only work with curves and object ids as the seed. Just a heads up :).
DriesV
Quote from: soren on May 20, 2015, 12:14:39 PM
That sounds like it should do the trick. :)
Didn't realize the Color Randomize node was intended for curves. Learning as I go.
