Mouse Control of image rotates in a weird plane
Started by jgerent, May 27, 2015, 10:37:28 AM
jgerent
Hi, I have Keyshot 5, as a part of Spaceclaim, and is activated or started in a "Spaceclaim session", the problem I have is the image of my model rotates in a weird plane, kind of 45 degrees to the screen, I can control it in a 360 degrees rotation, but cant get it to go in the position I need to render it, which in this case would be a front view. Any idea what happening here?
Since we are not developing the SpaceClaim plugin I can only guess. Check your camera and make sure that the twist angle is set to 0ยบ.
Hope this helps.
jgerent
Hi, thanks for the reply, I checked the Camera settings and didn't find anything to allow seeing to your recommended value, I did notice toggling the Perspective, Orthographic setting on and off seemed to fix the issue, so my process will be to use "Orthographic" to get into position, then switch to Perspective to get a better view...
Thanks for giving me a area to look into... :)
