Pauseing RealTime render
Started by m2tts, November 04, 2010, 10:53:45 AM
m2tts
In the announcement for the latest version of Keyshot it was mentioned that if you chose "Real Time Render" as your rendering mode that you could pause the render, and then pick it up again. How do we do that?
m2tts
Hitting the stop button stops and saves the rendering (not having time or frames checked);the window closes. How do you pick up where you left off?
You are correct - we will check into this.
