1 Hour
1 Day
1 Week
1 Month
Forever
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Help
Search
Login
Register
KeyShot Forum
Technical discussions
Data Import
Pro/ENGINEER - Creo
Problem with importing files
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Problem with importing files (Read 4875 times)
Detox
Newbie
Total likes: 0
on:
June 17, 2015, 06:29:50 am »
Hello guys,
as you can see in my attachments, I've got the problem that my assembly flies into pieces when i try to import it.
I still cannot use the Creo plugin somehow although i followed the instructions.
Anybody else who had this problem before?
Logged
KeyShot Beta
Hero Member
Total likes: 2
Re: Problem with importing files
Reply #1 on:
June 17, 2015, 08:16:26 am »
That looks like Y, Z axis confusion to me, I don't have Creo nor the plugin so can't test it here. In the scene Parts list, can you select the root object, then click the position button, if it shows -90 degrees on any axis, try setting it back to 0 and see if it looks better then.
Logged
Detox
Newbie
Total likes: 0
Reply #2 on:
June 17, 2015, 08:51:38 am »
Well thats something I did really NOT think about
I will try that and tell you if it worked. Thank you mate!
Kind regards,
DetoX
Logged
Detox
Newbie
Total likes: 0
Reply #3 on:
June 17, 2015, 08:53:05 am »
Looking at the con-rod that flies somewhere around i get a little bit skeptical. But I will definitely try that.
Logged
Guest
Reply #4 on:
June 17, 2015, 12:49:55 pm »
This looks strange.
And what is the problem with the plugin? Why are you not able to install?
Logged
Print
Pages: [
1
Go Up
« previous
next »
KeyShot Forum
Data Import
Pro/ENGINEER - Creo
