Help with this material
Started by rahulgs, June 21, 2015, 12:35:26 AM
rahulgs
Iam stucked with this material attached. I have tried several ones but the client is not satisfied. Can anyone help with this. The client needs the blemishes exactly like in the original picture.
rahulgs
Anybody can you please help me how i can replicate the surface patterns or blemishes just like in the picture of this stainless steel?. It is very needy. I have tried several map and searched everywhere but no success.
Which version of KeyShot are you using ? I would say version 5 can do this. Look at the Normals maps and use some scaling and you should get pretty close :)
rahulgs
Quote from: TpwUK on June 21, 2015, 08:55:40 AM
Iam using keyshot 5
Good - Have you looked on the KeyShot Cloud ?
I have been looking closely at it and I think the bump map is something like a scan code or a bark material, so i am trying to play and see what i can do
rahulgs
Yes i looked keyshot cloud but couldn't find suitable bump and also i don't know what to look for as this pattern is rare for steel. The model i need this to apply is attached(pic). If you find a solution then it will be very helpful.
Esben Oxholm
Hi rahulgs.
I gave it a go. It is by all means not perfect, but it might help you anyways.
You can download the .ksp and check out the details here:
https://www.dropbox.com/s/m1k59bya6bv1ibs/Material.ksp?dl=0
Good luck with the project.
Best regards
Esben Oxholm
Arn
Great job! Very recognisable as printed steel.
