Can't use multiple camera switch events
Started by Winch Doctor, July 16, 2015, 12:15:03 PM
Winch Doctor
Hi Keyshot,
I'm trying to create one solid animation with camera switch events, and cut up these into separate clips in Premiere Pro. However, after the third camera switch event it ignores the cameras prior to it. Here's what I've been doing:
1. Begin the animation with camera 1. Other camera animations play.
2. Create a switch event "from camera 1" "to camera 2".
3. That works fine. Create a switch event "from camera 2" "to camera 3".
4. Also fine. Create the next switch event in the cycle. Now while I should have a linear progression of cameras, instead the entire animation takes place from the perspective of camera 3, and now only the most recent camera switch (from camera 3 to 4) functions correctly.
The only thing I've done differently at this point is group my animations (leaving the camera switches OUT of all groups, if that matters). Also, if I delete or hide the most recent switch event, everything returns to normal.
-Windows 7 Professional
-Keyshot 5.3.6
-Plugin version? Um, Keyshot HD + Animation?
-Created in Solidworks 2015
-steps taken described above
-File being sent through WeTransfer
