Queue (for batch rendering) not working on my copy of KS 2.1.25
Started by rod, November 15, 2010, 11:54:59 AM
rod
I hit "Add Job" and no files are added to the queue. However, there is a brief flash that job has been added (similar to what happens when you save a rendering). When I hit "Process Jobs" KS will not render. Anyone else having this problem? What could be the problem?
Thanks, Rod
Can you check where you Scenes path is pointing to? You can check this in the Preferences.
rod
Thanks Thomas. I added a hard drive to my workstation and installed Windows 7. The path in preferences was set to the Windows XP version of the install. I changed the path and it now works.
Rod
