Ford Mustang Boss 429
Started by Alang7™, August 08, 2015, 02:44:30 AM
Alang7™
Working on a new car. I spent time on matching the perspective, so, before that i start the rendering, i want ask you if it fit good with the backplate. :)
So, tell me guys ... do you like it ? :)
Use the concrete cast lines for blue and red axis, then use the door frame or gutter pipes for the green axis - Then you should be set :)
Alang7™
Thank you Martin. :)
Does it looks better now ?
Angle is good, scale is a little off and needs a ground plane in there to trim off the tyres to make the car look as if it has some weight
Alang7™
What you mean ? I add a ground plane, and then ?
Open up its material options and set it to clip geometry below ground plane, then move the ground plane up n down to get the bottom of the tyres looking flatter :)
Alang7™
#6
I added, moved a little bit up .. nothing happens, i see no difference  :(
EDIT: Oh yea, it works good :D
So, tell me mate, i can render it ? :)
Do a max time and set it to ten minutes and see what you think :)
If you aint sure, post the rough and i'll have a look
Alang7™
I did a try with low settings:
Yep looks better - needs scaling though - looks too large still. I would move the front wheels to that cast line in the concrete and then check the length of the car compared to the concrete slab it is stood on
Alang7™
Yes very much like that !!
Alang7™
Okay mate, i will make the rendering then.  :)
Thanks alot for your tips, i really apprecciate it! :)
Alang7™
Nailed it!  Maybe lighten the tires a VERY small amount, but that's just my opinion.  I've used this backplate before, and it can be very deceiving.  Good job!
