Weld texture/material
Started by bowen192, August 25, 2015, 02:49:45 AM
bowen192
Has anyone here created a weld material or found a weld texture to use?
I think Aluminium Hammered is the closest out of Keyshot supplied materials.
Most if not all of the weld examples i have seen have been done with geometry. If you are a poly modeller the welds are pretty easy to model.
mafrieger
Hi
was just looking for the same topic.
did you find a way to do it in a good looking easy to setup way?
What I found was this one:
https://stilllifeinslowmotion.wordpress.com/2011/01/16/adding-a-weld-displacement/
maybe one can adopt it to be used in Keyshot.
