Region Render under Windows 7 doesn't work correctly
Started by Zeno1138, November 30, 2010, 11:21:13 AM
Zeno1138
When I go to region render under Windows 7 using the newest KeyShot version
I don't get the bounding box to choose a region.
  The only available point is in a top left or bottom right corner and the rest are invisible.
Typing in a coordinate number also didn't work.  I also tried in full screen mode.
JeffM
Try changing the region position values to 50 for each value. This should bring the region into your frame and should shape a small square. You can then drag the corners to where you need them.
Ralf-S
Hi Zeno1138,
I also use Win 7, please take a look:
Zeno1138
