Problems with Rhino Live-link in combination with sun & sky in Keyshot 6 Pro
Started by ralemalph, November 19, 2015, 11:48:33 AM
ralemalph
I am working with Keyshot 6 Pro, using the Rhino Plug-in.
In combination with the Sun & Sky environment, strange things happen after changing some settings like location or time.
The result is the same using the live linking with or without NURBS.
When I do not use live linking but just save the Rhino file and import that file into Keyshot, the results are ok.
So it seems to be a problem of the Plug-in.
The pictures show the situation when a simple block has been imported  with live-linking and sun & sky has been activated. This initial result is ok.
The other picture shows the effect after changing la setting in sun&sky, like location or time. Note that also the colour of the block has changed.
The software / system specifications are:
Windows 7 Home Premium 64 bits
Keyshot 6 Pro 6.0.264
Rhino Plug –in: (keyshot6_rhino5_plugin_1.0)
Rhino 5 Version 5 SR12 64-bit
(5.12.50810.13095)
Hardware specifications are:
HP h8-1102
I7-2600 CPU 3.40 GHZ
16 GB RAM installed
Graphic card Geforce GT530, driver up-to-date
Hope you can help.
