Author Topic: Keyshot6 plugin crashes in Cinema 4D R17?  (Read 8552 times)
Offline tennet
« on: November 28, 2015, 11:37:49 am »
Hi! Just trying to render from Cinema 4D R17 to Keyshot 6 Pro using the Cinema 4D plugin (latest download). When I hit 'Render' (from the plugin in C4D) then Cinema 4D crashes directly. I can click 'Export' (still in the plugin) and save a .bip file from C4D, which can be opened correctly in Keyshot.. but I'd like the "render directly" button to work also. Same happens if I click "Update" in the plugin, Cinema 4D crashes.
Am I doing something wrong or is the plugin not working? Have tried it on two different Mac's.
Offline tennet
Re: Keyshot6 plugin crashes in Cinema 4D R17?
« Reply #1 on: November 30, 2015, 03:16:25 pm »
Apparently this is a known bug and it will be fixed in the next release of the plugin, according to Luxion support.
Offline Finema
« Reply #2 on: November 30, 2015, 09:32:01 pm »
Where can we find the same plugin for Keyshot 5 ?
Offline Artur
« Reply #3 on: March 09, 2016, 12:18:36 am »
Hello Keyshooters,
I have installed according to the read me file the plugin for cinema 4D R15 and the plugin is not loading into the UI.
Have you any solution for this problem?
Thanks in advance.
