how to? compression of a spring or an elastomer block
Started by hpvd, December 14, 2015, 02:11:44 AM
hpvd
Hi Keyshot Users,
do you have any idea on the best way to animate the compression of a spring or an elastomer block?
Of course the deformed geometry could be obtained from a calculation software e.g. as stl-file.
But how to deal with them?
Do one need only non compressed and fully compressed geometry (start and end postion)? Or many steps between?
Many thanks for any idea!
Esben Oxholm
Hi hpdv.
This is not possible with KeyShot (I'm pretty sure, but correct me if I'm wrong)
Which software solutions do you use? How to animate it depends a lot on that.
hpvd
deformation geometry could be e.g. obtained from Ansys.
One  idea was to export e.g. 100 stl files, one for each step of compression and fade in/fade out these geometries one by one...
But this seems of course not to be the easiest approach... it has the advantage of realistic deformed geometries.
Could it work this way? Could one achieve a smooth animation?
what I found is this video but not with realistic material and lightning / keyshot
https://www.youtube.com/watch?v=ztdpHYmDalc
You need a 3rd party app such as C4D, Blender, Maya, Max etc. Then you need to export your animation as Alembic Cache (*.abc) or a sequential OBJ where each frame is exported as OBJ. KeyShot 6 supports both sequential and alembic animations via scripting
hpvd
thanks for pointing to needed direction!
These days there is a related discussion in scripting topic:
https://www.keyshot.com/forum/index.php?topic=11615.0
PhilippeV8
What we REALY need is 1 axis scale animation ............. can't believe it's hard to implement and can't believe it is not in KS6.
