3ds max Plugin UV problem
Started by picfad, December 20, 2015, 12:05:25 PM
picfad
Hello.
I use latest plugin for 3ds max.
When i hit "render" or "export" in keyshot plugin in 3ds max 2014.
1.And put texture in keyshot - texture dont apply when i use uv coordinate ( if this texture dont apply in 3ds max ) - simply i see nothing
2.If i put texture in 3ds max , uv coordinates in keyshot  work perfect.
3.If i use standart export without keyshot plugin - all work correct.
Dear developers can you fix this issue.
Thank you!
