ABC import from Maya
Started by stezza, January 18, 2016, 06:47:34 AM
stezza
Hi folks.
I have a simple plane which has been rolled up like a carpet, using linear bend deformer.
I export as abc from Maya but on keyshot import there is no animation, just object.
Is there a different workflow with abc files?
Many thanks
S
jt_pedersen
Make sure that you are exporting the animation, that is it may need to calculate the physics and that is not part of a default alembic file.
I believe you have to use "cache"->"alemebic cache"->"export all to alembic"
