Lonely Chair
Started by Magnus Skogsfjord, February 15, 2016, 05:25:46 AM
Magnus Skogsfjord
Quote from: NM-92 on March 15, 2016, 09:43:01 AM
Wooden floor on 1.74_2.png image is simply spectacular. Can you share how you did this ?
Thanks! Sure, there's really not much to it. I was thinking about sharing it, but I noticed it's not seamless. Anyway, as seen on the material graph, it's a simple plastic material with a diffuse, spec and normal map(very subtle bumbed). The lighting from behind is a simple IES spot light to put an emphasis on the roughness / specularity effect.
Quote from: threedyart on March 16, 2016, 02:06:16 AM
amazing texture
Thank you thank you:)
