Keyshot plugin in Fusion 360 doesn't work
Started by Rafal911, February 24, 2016, 01:09:27 AM
Rafal911
Hi. I am trying to install the Keyshot plugin for Fusion 360. I tired more times without success. The installer says that the installation was successfully, but The Keyshot plugin is anywhere inside Fusion 360. I tired also the manual installing method, but the folder  /temp/Kesyshot (As the installation guide says) in nowhere neither. I tired copying all the files from the Package into the "Manually installed" scripts into the application support folder from Fusion...without any changes. I tried also uninstalling Fusion and tried to do a clean installing process of the Keyshot plugging, but again, i became all the same error.
Can someone help me with this bug/issue?
Thanks a lot
To be honest this is not a technical discussion, you need to post on this part of the forum https://www.keyshot.com/forum/index.php?board=11.0
When or if you post there can you provide more details ... KeyShot version and OS version any error codes that you may see
Rafal911
