Can't see my shadows
Started by Crings, March 21, 2016, 04:06:56 AM
Crings
Hi there,
I need your help, because I can't find the answer anywhere.
I can't see my ground shadows either when set to lighting environment, color or backplate image.
Both Ground shadows and ground reflections are enabled.
Can someone please help me  :-/
Esben Oxholm
Have you checked if your model is below or way above the ground?
LayC42
This issue sounds like:
- wrong scene unit
- virtual ground dimensions too small
- 'unlucky' HDRI environment
Plz share the solution or some screenshots from the project window tabs (or share your current scene without geometry or with a dummy part)
Crings
Thank you so much! The solution was simply to check the "snap to ground" and then move the model around with "select look at point" instead of "move model"
Thanks for helping a rookie :)
- Christine
Esben Oxholm
