Can't see the caustics
Started by Zvi, March 30, 2016, 05:10:56 PM
Zvi
Why in the image with the lying floating perfume bottle I can't see the caustics of the perfume on the surface, although there is an IES light? I'm attaching a print screen with the lighting settings.
Finema
Do you have a groundplane on your scene ?
Zvi
Quote from: Finema on March 30, 2016, 08:37:02 PM
I'm using an imported surface as groundplane.
Esben Oxholm
Hi Zvi.
Are you able to share the scene?
Zvi
Quote from: Esben Oxholm on March 31, 2016, 03:50:55 AM
Hi Zvi.
Yes. Thanks again.
Esben Oxholm
Thanks.
There's something fishy about your glass. Maybe it's the way it is modeled. I couldn't get the caustics to show with any type of glass-material and/or setting. I suggest that you model and split your surfaces the way that Richard shows in the other post of yours: https://www.keyshot.com/forum/index.php?topic=12259.msg59849#msg59849
Without the glass the caustics shows up just fine.
Zvi
Quote from: Esben Oxholm on March 31, 2016, 07:18:59 AM
Thanks.
OK. I'm going to check it.
Can you tell me how did you animate the movement of the gem stone?
Esben Oxholm
Quote from: Zvi on March 31, 2016, 10:34:31 AM
Sure. It is just a 360 rotation along one axis, while rotating 360 degrees along another axis.
Zvi
Quote from: Esben Oxholm on March 31, 2016, 10:46:45 AM
Thank you very much, you're so kind.
