Wireframe Material
Started by Jesse.Art, May 10, 2016, 11:12:23 PM
Jesse.Art
Is it possible to render out a quad wireframe instead of tri's yet?
#1
Quote from: arsmod on May 10, 2016, 11:12:23 PM
Out of pure curiosity, what advantage would you get from quads or tri's ?
No because KeyShot doesn't show quads, only triangles.
Jesse.Art
Quote from: TpwUK on May 11, 2016, 12:36:26 AM
Out of pure curiosity, what advantage would you get from quads of tri's ?
Not necessarily advantageous but rather a personal preference. I find the tri's wireframe to be a bit more dense than I like.
Jesse.Art
Quote from: thomasteger on May 11, 2016, 05:50:15 PM
Yeah, I was hoping somebody had figured out a way. :(
Quote from: arsmod on May 11, 2016, 10:14:55 PM
That's what i was trying to get to, was it for personal taste or something more technical. You could possibly create a new material that was a wireframe type of material but designed not to show the diagonal lines of the mesh, or maybe KeyShot can add one for a future release. I must admit the nice smooth looking quads display you get when working in SubD packages do look much better to the eye :)
#6
There is a way to render quad wireframes in KeyShot.
It requires a model with planar quad faces to work.
Here are the steps:
  • Import model with planar quads.
  • Completely unsmooth normals (Edit Geometry > Edit Normals > Minimum Edge Angle = 0° > Calculate Vertex Normals).
  • Assign Toon material.
  • Set very low Contour Angle for the Toon material.
I attached a simple example scene and rendering.
It works on dense meshes too.
Nice examples, are they NURBs or Polygons ? I suspect the former since KS always triangulates polygons
#9
Quote from: TpwUK on May 12, 2016, 04:55:04 AM
Polygons. The trick lies in using the Toon material. The Toon shader doesn't apply a contour line if the angle between two faces is 0 deg. So eventhough there are still triangles, the Toon material makes the model look like a quad mesh.
If you import planar quad meshes, then each quad will be converted into 2 planar triangles.
In general, this technique creates cleaner looking meshes when compared to the regular Wireframe material. Especially for models that have a lot of planar geometry.
Left = Toon / Right = Wireframe
Jesse.Art
Quote from: DriesV on May 12, 2016, 03:00:13 AM
Here are the steps:
Much appreciated but I still get tons of triangles throughout the mesh.
Jesse.Art
It appears that I don't have all planar quads. Is there a way to achieve this without triangulating them in Maya?
Quote from: DriesV on May 12, 2016, 06:47:56 AM
Excellent examples, and certainly a method I will have to look at. I couldn't tell that the torus was a poly mesh :/
Jesse.Art
I found a solution that works for me. I simply exported the UV map image from Maya's UV Editor and brought it into Photoshop where I prepped the image as a texture and applied it to a KS material.
Perfecto
