Author Topic: Poliigon Textures  (Read 14542 times)
Offline richardfunnell
Poliigon Textures
« on: May 12, 2016, 01:11:46 pm »
For those of you looking for high quality image textures that can be used in KeyShot, check out Poliigon: http://poliigon.com
This blog post has more information about the launch, but it may be a great resource for high resolution images. Luxion doesn't currently have any formal association with them, but the content seems to be top notch. I've attached a few quick images created using their textures; the image name includes the texture used.
Launch post here: http://www.blenderguru.com/articles/introducing-poliigon-new-texture-site/
Offline Esben Oxholm
  • KeyShot Beta
  • Total likes: 6
    • Freelance CG Artist
Re: Poliigon Textures
« Reply #1 on: May 12, 2016, 01:39:01 pm »
Thanks for heads-up, Richard.
It's always great with another ressource site.
That reflection in the last material is looking sweet!
« Reply #2 on: May 13, 2016, 07:57:39 am »
Thanks Esben!  Mappable roughness may be one of my favorite features in KS6, and I've shown a few of your examples that use roughness textures in trainings & customer demos :)
Offline Finema
« Reply #3 on: May 13, 2016, 08:22:00 am »
Thanks Richard for this link !
can you show us or share  your material  using  Metal Grime 006
I can't reproduce it
Thanks a lot
« Reply #4 on: May 13, 2016, 12:44:10 pm »
Attached is a breakdown of the material graph, and here are the modifications I made to textures & settings:
Material: Plastic (Transparent) Diffuse color was black, Refraction Index of 2.
Textures: Specular, Roughness & Normal.
- I changed the projection to Planar Y since this was a flat surface, giving me better results for the Normal Map.
- The roughness was controlled using the Color to Number Utility Node; this allowed me to control the output to a range of 0 to .2 for the roughness.
I can't share the material, but let me know how this works for you!
Offline LayC42
« Reply #5 on: May 13, 2016, 01:46:55 pm »
Hello Richard.
Thank you for sharing this.
Offline Finema
« Reply #6 on: May 13, 2016, 10:00:20 pm »
Thanks a lot Richard !
Offline Finema
« Reply #7 on: May 13, 2016, 10:46:27 pm »
Can you show us how to use the overlay textures ?
Thanks again.
« Reply #8 on: May 27, 2016, 10:49:59 am »
Hi Finema,
KeyShot doesn't have overlays, but you can apply these textures as a label then change the material for it.
Another option is to use them as a roughness texture, the attached image shows that result. Instead of defining roughness for a material globally, you can define roughness with a texture: Black is roughness = 0, White is roughness = 1.
You can also use the "Color to Number" Utility node to define the output range, for example setting the "Output From" to .01 and "Output To" of .2. Much easier to think of roughness in numerical terms instead of color :)
Offline Finema
« Reply #9 on: May 27, 2016, 11:09:47 pm »
Thanks Richard
Offline Will Gibbons
« Reply #10 on: May 31, 2016, 09:46:22 am »
Great find and good tips about the color to number to drive the roughness values!
Offline bdesign
« Reply #11 on: May 31, 2016, 10:06:36 am »
I find the Color To Number node to be one of the most versatile of all the nodes. So many different ways one can use it to drive various parameters. I use it in one or more ways with the majority of material networks I create. Great node.
Eric
