Other menu layout option(s)
Started by NormanHadley, May 19, 2016, 05:47:59 AM
NormanHadley
Hi Keyshooters
One thing I'd like to see is the (quickly set up) option of having the render window full-width on one screen of a two-screen setup, with the library, project and geometry windows tiled on the other? Is that possible? Example layout below.
jasonbaldwin
Yes it's possible using the grab bars and pushing and dragging things to the opposite sides of the screens. Sadly the layout never saves with the file so you have to do it all again, or at least that was my experience :/
LayC42
KeyShot saves the dialog position inside the keyshot.xml as well. Tested in KeyShot 6.1.72 with a german interface (but I think that this doesn't matter)
NormanHadley
That's pretty good, LayC42 -  I'm just wondering if there's an even neater tiled arrangement on the LH screen that would snap into place. (Probably being over-finicky)
